Append For Loop values to an array
I am using a for loop to iterate through about 20 steps of acquisition (10 samples, 1000 hz each iteration).  I then want to save all this information (a total of 200 samples from all of the 20 iterations).  Ideally, I would like to append all this information to a single array and then graph the information.  I also need to save it.  I am having trouble saving all of the iterations as I am only able to save the final iteration's informations.  Please help!
Emily
(3,267 Views)
Using dynamic data is not something I would recomend and building an array of it is almost certainly a bad idea.
If you stick with dynamic data and express VIs, use the Append Signals with just a shift register and no build array function.
(3,264 Views)
