Can't open the driver written by LabView5 with LabView 8.6
http://www.oinst-software.com/OIRI/docs/LV5drv/lv5drv.htm
I would like to use these drivers for oxford instruments with LabView 8.6. (I have the latest version of LabView, only.)  But these drivers are written by LabView 5. So, I cannot open the drivers with the latest version. When opening, the alert occurs "VI version is too early to convert the current LabView version." In this case, is it no way to open these drivers. Does anyone help to convert these drivers for use with the latest version ?
Message 1 of 9
(4,070 Views)
You should attach the specific driver that you want converted.
Message 2 of 9
(4,065 Views)
Dear Dennis Knutson,
Thank you for your response.
I need to use immediately the attached two drivers at least.
Magnet Power Supply - IPS/PS
Level Meter - ILM
Is it posible to convert them for ver.8.6 ?
Message 3 of 9
(4,035 Views)
The mass compile to 7.1 generated some errors because of some missing .ctl's. You can disconnect them from the type def or recreate them.
Message 4 of 9
(4,027 Views)
Thank you for your help.
I just try to use them.
If any troubles, can I ask again?
Thanks.
Message 5 of 9
(4,023 Views)
I have the same problem. I can not open the Lambda Controller with Labview 8.6. I attached the old verson(5.0). Could you help to convert. Thank you.
Message 6 of 9
(3,871 Views)
I really need someone help me out.  Thanks.
Message 7 of 9
(3,820 Views)
I have already received the latest version of Oxford's VIs, which can be running smoothly with the latest version of LabView. You may ask the support team of Oxford Instruments to supply the latest version of VIs.
Message 8 of 9
(3,802 Views)
Thank you  for the information.
Message 9 of 9
(3,798 Views)
