07-19-2022 01:40 PM
Hello, Im trying to understand from time to time how EACH vi works.
Got to "append list to report", dug a lot, cannot find any working example or good explanation (labview documentation is really bad)
Example attached.
I'm getting 41000 error on this node.
Please advice what I'm doing wrong.
07-19-2022 02:36 PM
I thought appending a list to a report is more for "Word" reports, not "Excel". (If you chose a word report, it works just fine)
Is is also a really (really!!!) bad idea to write to the root folder (C:\raw results.pdf). Windows wont allow that.
07-19-2022 02:39 PM
You right.
After a lot of tries I found that it only work with word and html.
They simply could write it somewhere (
About file saving, I just deleted the full path for the example. Indeed a bad idea to save there. Not doing that )
07-19-2022 02:42 PM
@Altenbach is almost certainly correct -- you have found a "Bug in the Documentation".
This functionality is designed for "Text" reports that can be generated to be read by Humans (and not processed by Spreadsheets such as Excel). Here a "list" means "a vertically-arranged column of text, either sorted or unsorted, with a possible indicator such as a Bullet symbol or a numeric entry that indicates the sequential serial order ("1, 2, 3" or "a, b, c")".
The Error Message is "NI-Reports: (Hex 0xA028) You attempted to use a function that has no effect with the current report type." This information belongs in the Help file for this function. I'm sure that @Altenbach will bring this to NI's attention.
07-19-2022 03:36 PM
Of course, there is always the "Submit Feedback" button in the help file. PRESS IT! NI actually put it there for you to use.
