Append to an existing report
Hi Everyone,
Is there a way to append a report to another existing one. I mean, I have already saved and closed a report as a HTML and I want open and add more data and figures to it. I'm using LavVIEW 8.0.
Any help would be appreciated.
Mike
Message Edited by q123456789 on 02-10-2007 01:18 AM
(3,154 Views)
You should be able to use the append file to report.VI for what you want to do.
Joe.
"NOTHING IS EVER EASY"
(3,140 Views)
Thanks Joe,
 I used this vi before, but it deals with the existing report as text. So, the final report I got, (the existing and added repot)  is unformated. Could you please explain more.
Mike
(3,139 Views)
Hello Mike,
       I could not find a VI that would open an existing HTML report.  Without an "Open Report" VI, you cannot get a reference to your pre-existing HTML report.  I recommend opening both html files as text files, concatenating those strings and then replacing the pre-existing HTML file with the combined string.  I tested it with just adding some line breaks at it seemed to work fine.  Let us know how it works for you.
Cheers,
NathanT
(3,118 Views)
