Dear Madam/sir
May i know how to remove the noise from the .wav file and can you tell me how to filter the noise signal from the corresponding file
these are the files i tried to remove the noise signals but i couldnt make it i am very helpful to you if you correct this error.
for eg.
type:wave sound
Bit rate:252kbps
type:wave sound
bit rate:705 kbps
type :wave sound
bit rate:176 kbps
