Appending to a Datalog file
Using the Reshape Array function is the solution I was looking for.  I knew there had to be a better way than my For loop contraption.  Now retrieving the saved data is near instantaneous; even for very large files.  I've attached the change made to the log example vi in case it's helpful to someone else in the future.
Thank you for your help.
DJ
Message 11 of 11
(594 Views)
