01-07-2007 06:49 AM
01-08-2007 03:33 PM
01-08-2007 08:57 PM - edited 01-08-2007 08:57 PM
Message Edited by Raghunathan on 01-08-2007 09:01 PM
01-08-2007 09:31 PM
i have no problem adding a folder... i think you are facing the problem of adding the parent folder because you must go into the folder before pressing the "Current Folder" button...
for example, you want to add the folder name DataFolder which is under the folder called Project... so to add DataFolder, you must go to Project -> DataFolder then press the "Current Folder" button.... like that you'll be adding all the current and child folder of the DataFolder folder... hope this helps... ![]()
01-08-2007 09:41 PM
01-09-2007 07:49 PM
