Application Builder Dialog Box
I have a funny with the application builder when performing a Build All. If I have more than one build, say two executables plus an installer, the text in the Build status dialog box does not update, it will say "Building 1 of 3" even though the progress bar has moved onto the 2nd build.
Its not really a bug as such but it would make more sense if the text kept up with the progress. I see this in LabVIEW 2011, but I am sure I have seen it in earlier versions of LabVIEW.
(3,475 Views)
I have the same behavior in LV2013.  I haven't built anything in 2014 yet so don't know if it has carried forward.  If I select "Build All" then I only see the first message about what is being built even though everything actually builds.
I would call this a bug, just not a real important one.
Kelly Bersch
Certified LabVIEW Developer
Kudos are always welcome
(3,426 Views)
