Application Builder - I just get NaN when I run the install. Help!
If the machine that this program does not work has MAX (Measurement and Automation Explorer) check in there and make sure that the dieve is showing up as the same devX number.
I.E. if your board is dev1 on your laptop and dev0 on the other computer, then your program is pointing at the wrong device. If not, you can rename the device in MAX to the same devX as your laptop.
Message Edited by StevenD on 06-11-2008 08:49 AM
Message 11 of 14
(684 Views)
That's it!  Thank you so much.  The laptop has had 2 different data acquisition boxes plugged into it, where my machine has had only one.  By changing the identifier, everything lined up again.
Thanks!
Mike
Message 12 of 14
(678 Views)
I am getting the same thing with a build of mine. I have also noticed, that if I run the build on the source or target computer I get the same results(NaN). But, when I run the *.vi I get good results.
Message 13 of 14
(623 Views)
Hi Shawn,
Did you take a look in the Measurement and Automation Explorer to see if the device name is idential in your build and your VI?  ("Dev1" for instance)
Kevin S.
Message Edited by Kevin_S on 12-02-2008 10:58 AM
Message 14 of 14
(606 Views)
