Application Builder - LabVIEW Compatibility
Hi all,
I like to know if I upgrade me LabVIEW Full to 2016 version, will I still be able to build exe with my Application Builder bought in 2011?
(4,260 Views)
Good question!  I believe that your app builder for LV 2011 will stay intact.  I'd check with NI just to make sure though.
Bill
CLD
(Mid-Level minion.)
(4,242 Views)
Accepted by AYPYoo
You need the 2016 application builder if you want to use it with LabVIEW 2016.
In order to keep using the 2011 application builder, you also need to keep LabVIEW 2011 installed.
I am sure NI will give you an upgrade path for both. Maybe you can upgrade to LabVIEW 2016 pro, which includes the application builder. Contact your sales rep.
(4,230 Views)
Thanks for this. I'll put up a proposal to my management.
(4,173 Views)
