02-05-2007 01:25 PM
02-06-2007
03:04 PM
- last edited on
02-08-2026
02:11 PM
by
Content Cleaner
Hi Int_man,
1. Unless you notice CPU usage skyrocketing to 100%, probably not.
2. "LabVIEW requires a minimum of 256 MB of RAM, but National Instruments recommends 512 MB of RAM." This information is available in the LabVIEW 8.0 Release Notes
3. The size of an application usually takes a back seat to array/cluster sizes. Branching large arrays and passing between local variables cause memory usage to increase X-fold. To quote Dennis, " The amount of RAM used is more a function of what your program is doing and how it is doing it than the size of the source files."
I recommend taking a look at the Faster build discussion forum. There are many helpful suggestions for optimizing the App Builder build time.
Cheers.
