Application Builder hangs on Processing Merge Errors.vi
I am having a problem building my applciation as an executeable in 8.2.1.  During the build process, LabVIEW hangs indeffinately while Processing Merge Errors.vi.  I have mass compiled my source directory, and my LabVIEW directory.  I have even repaired all of the NI software that I have installed.  I have also created a new project and build specification from scratch in case that was corrupted.  I created a test project where the only VI was a call to Merge Errors.vi and this build just fine into an .exe.  I am at a loss to what the problem is or how I can fix it.  Any help would be greatly appreciated.
thanks,
(3,087 Views)
Hi Faraclas,
What operating system are you using? Does it only hang when you have this vi? Can you create an executable without this vi?
Juan Galindo
(3,075 Views)
