My source code runs fine (and Draw Arc.vi does its job) but when I try to build the Application I get an error:
"Error 1 occured at Draw Arc.vi:\."
Draw Arc.vi is in C:\Program Files\National Instruments\LabVIEW\VI.LIB\PICTURE\picture.llb
What is error 1? I could not find the Application Builder error codes explained anywhere.
Any suggestion is welcome. Thank you!
P.S. The VI settings for Draw Arc.vi are: Remove Debugging: yes, Remove Diagram: yes, Remove Panel: no.
