Application Builder uses localized decimal point
I am building an application which will run in countries that use a comma instead of a period for a decimal point. I have turned off the option USE LOCALIZED DECIMAL POINT under options for Labview. This works. However, when I build an EXE using the application builder, the setting is not transferred to the EXE, and the application will not run. Is there a way to set the application builder to not use the localized decimal point?
(4,508 Views)
When you run your application "myapp".exe for the first time you will notice a file called "myapp".ini is created in the same location as the executable. You need to add the key:
useLocaleDecimalPt=False
to that file. Now rebuild your application and make sure that "myapp".ini is included in your support files and is installed into the same directory as "myapp".exe.
-Jim
(4,512 Views)
Thanks Jim, it works just fine.
(4,510 Views)
(4,510 Views)
Also remember the [MyAppName] line in the .ini file - see this thread
Martin
(4,252 Views)
I did as you describe and the App works fine after editing the <app>.ini file
I also copied the <app>.ini file into my work dir, included it in my project and put it to the "alsways included" list
as soon as i publish the app again the settings are gone and I have to put the line "useLocaleDecimalPt=False" back manually
any idea how to solve this?
TIA
Nitedula
(3,766 Views)
Hi Nitedula,
don't use the "always included" section - uncheck the "Use the default LabVIEW ini" checkmark in the advanced section of the Build properties!
(3,751 Views)
