Application Builder
I am using Labview 5.01 with the associated application builder. I have a
LLB which consists of 4 top level vi's and numerous sub vi's.
All of the vi's run fine with no errors. However, when I compile it to an
executable using the "Build Application" command, the resulting appilcation
indicated the vi's are broken (broken gray run arrow instead of white one).
When I click on the run arrow, it gives an error message that says "A subvi,
type definition, or external subroutine is missing or inconsistent with the
vi". For the life of me, I can't figure this out. Any help would be
greatly appreciated.
Ed Haack
ehaack@carolina.rr.com
(2,861 Views)
Dear Ed
Not an answer I am afraid, but I have had this sittuation and found that moving one of the NI subVis from its Vi library and saving it as Windows file worked around the problem.
Unfortunately I now have the same problem and cannot cure it with the above method.
I realise the time difference between you having this problem and now, is large, but maybe it will be of interest and start a thread so that I can cure my problem.
Regards
Steve Munnoch
(2,861 Views)
