I need to stop working task's in ordinary shutting
I working with LABVIEW 6.1 .I need to stop working task's in ordinary shutting.The task's working indpendently , if someone have any idea i will be greatful.
(2,724 Views)
Can you elaborate on this question?
What tasks are you running? What do you mean by ordinary shutting? Do you mean just pressing the abort button in the menu bar?
If you have any hardware operations, it is not recommended that you stop the VI by pressing the abort button. It would be better to have a Stop Boolean. Since you have LabVIEW 6.1, you can use the Event Structure. Have a event case for Stop, and end all of the tasks in that case.
Zvezdana S.
(2,724 Views)
Dear Zvezdana
I am running many task's in the same time such as measuring ,acquire data etc. .
Ordinary shutting means stopping task's step by step ,
each working task will be stoped in the sequence we decide.
Pressing one button will close the task's step by step
until all the task's will be stoped.
I will appreciate your help
Koby Argov
(2,724 Views)
Dear Zvezdana
Koby Argov
(2,724 Views)
