Application builder doesn't show in menu
We recently received an upgrade to 8.2.1 LV and application builder. I've installed App builder with no errors but it doesn't show up in the tools menu as (I believe) it should. License manager shows it installed and activated. I tried un/reinstalling LV and app builder but the problem persists. Any ideas???
(2,895 Views)
Open a new project. At the bottom of the list you will see "Build Specifications." Right-click this and select New -> Application (EXE). This is where you create the application. If you previously used a version before 8.0, you would be used to building an application from a VI. It has now been integrated with the project window.
(2,882 Views)
If you don't have a project set up.
From an open vi, select Tools>Build Executable.
(2,876 Views)
Yup, you're both right. The last version I used that had the App builder was 7.0. Thanks alot for the help. Mark
(2,871 Views)
