Application built in LabVIEW 2011 installed successfully but not running on windows 8.
@Ranjeet_Singh wrote:
For 64 bit I found database and report generation tool.
Here it is. Hope this will work. they say it will
This is the 32bit version, which will work fine with 32bit LabVIEW on a 64bit OS. Earlier, you said you are looking for a version for 64bit LabVIEW. Who are "they"?
Message 11 of 16
(1,031 Views)
Hello TobiasK,
                                 I am able to run loabview 2011 in windows 8 successfully. Absolutely no problem.
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
Message 12 of 16
(1,014 Views)
Sir
                               I think this windows 8 was never a problem but AMD was. Actually both came at same time so I was not able to figure it out where was the problem.
One more thing, In the document what you provided (Which was very useful, thanks a lot) they say
delete the niCPULib.dll, and replace it with the niCPULib.dll in the attached CPU Patch LabVIEW 2011 32bit.zip.
what does it mean 'attached CPU Patch LabVIEW 2011 32bit.zip'
Ranjeet
--Ranjeet
Message 13 of 16
(1,013 Views)
Sir
--Ranjeet
Message 14 of 16
(1,010 Views)
Hey TobiasK,
                             I cant edit my last reply, what I mean to say is application built in labview 2011 is running properly in windows 8.
--Ranjeet
Message 15 of 16
(1,007 Views)
Sir
--Ranjeet
Message 16 of 16
(995 Views)
