Application created in LabVIEW hangs but works ok as a VI from LabVIEW
Application created using Build Specifications hangs when running as a standalone executable.
Hangs=Application does load and arrow says running but nothing happens. No user interface controls are clickable. Only way to exit the application except click on abort execution.
Same VI runs OK while running from LabVIEW.
LabVIEW 2018.
Message 1 of 11
(3,408 Views)
What does the application do? Interact with hardware? Access the network? Access certain folders, ini files?
Does it work better if you do a right-click...run as administrator?
Message 2 of 11
(3,407 Views)
Yes, it does interact with HW. It scans COMPORT and selects one. Doesn't access any folder or network locations. And HW is connected exactly the same way. I also tried copying exe file where VI is located unsuccessfully.
Also tried running as admin unsuccessfully.
Message 3 of 11
(3,390 Views)
Did you built an installer with all dependencies or just an exe that you copy around manually?
I assume the hardware is no longer still reserved by the VI.
Do you use any unusual antivirus or security software?
Message 4 of 11
(3,386 Views)
I think I found the solution.
I removed following .net calls and it started working OK.
Looking for some explanation.
Message 5 of 11
(3,331 Views)
Well without seeing your code we can only guess...
First guess is a race condition somewhere in your code that might have worked okay in the development environment but is racing when complied.
Second guess is you don't have a required runtime library such as NI-VISA or NI-488.2 installed on the target machine.
=== Engineer Ambiguously ===
Message 6 of 11
(3,351 Views)
Looks like there is an issue with this forum website. I posted the solution two times and it is not showing up.
(I copied/pasted screenshot) is that the issue?
Let me try again the third time.
Message 7 of 11
(3,347 Views)
I am trying this on the same machine. So no issue with run time or drivers.
After I "disabled" above .net call for getting file version and code works ok now in application mode.
One more note: My main VI is inside LLB. Getting VI ref is an issue in application mode?
Either way, shouldn't it pop up an error?
Message 8 of 11
(3,341 Views)
Isn't cutting out that code a little cutting your thumb off and saying that it fixed your hangnail condition?  Rather than lop off some code that seemed to have some kind of relevance, why not poke around and see exactly why this isn't working correctly?  (Unless, of course, you've declared your thumb to be a non-essential digit.  ;))
Will it throw an error?  Maybe.  Automatic error handling is disabled in an executable, so unless you are propagating errors through the error in and out of your subVIs, they will be swallowed.
Bill
CLD
(Mid-Level minion.)
Message 9 of 11
(3,321 Views)
Correct, issue is not resolved. I just pointed out where the issue is.
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000kIWRSA2&l=en-US
Message 10 of 11
(3,317 Views)
