Application created in LabVIEW hangs but works ok as a VI from LabVIEW
Accepted by topic author _TestMan_
I would use a Conditional Diagram Disable Structure to get the desired path.  In the Runtime Engine==True case, you are running an executable.  Use an application property node to get the application path.  This will get the version info of you executable.  In the default case, you are in the IDE.  So you use your current code to get the path.  This will get the version of your LLB.
Message 11 of 11
(312 Views)
