Application exe sub vi's missing
Hi
Hi
I made application Based on PCI 6221 DAQ card.
Hi
I build application.exe.
I build Installer that included  1) 2010 runtime engine  2) DaqMX drivers.
Hi
when I installed and run the application in client PC.
Hi
It gives Error code 3.
No source file found. Missing Sub Vi.
All the missing Sub vi's are related DAQmx.
I found that all the required Sub Vi files Exists in the Installation folder.
Hi
Any one please solve the problem.
Hi
Hari
Hi
Hari
(12,119 Views)
Accepted by topic author thinnker
Hi
Sorry for the above post.
Here clearly posted.
Hi
Hi
Hi
Hi
Hi
Hi
hari
(12,112 Views)
I'm not sure your second post more clearly explained anything.  And why is everything repeated several times in both messages.
And why did you mark your second post as a solution?  Go to the upper right corner of your message, Options Menu, and click unmark as solution.
If you want to get any kind of help, you need to clean up the message.  Say it once, say it clearly, and don't mark it as a solution because many people will skip right over your thread.
(12,079 Views)
Hi
Actually i wrote problem once only, but i don't know how it posted like that.
second time i tried again i got the same problem.
next time i tried another PC with new thread, then it posted clearly.
I marked it as solution becoz the post was not clear to understand what is the problem.
Thank you anyway.
Hari
(12,053 Views)
