DSC / Read Traces / waveform
On DSC, I am utilizing the Read Traces.vi to read the Historical Data on defined traces.
How can I map the output of this control (historical traces) to be displayed as a Waveform Chart?
On the Time Interval, how can I set the Start and Stop times so that the chart will always display the last 24 hr, for example.
Thanks!
Ezerhan
(3,034 Views)
Got the Historical Trend going with a proper time interval - Heat Exchanger.vi under lvdsc example directory gave some clues.
Still trying to get the hihi alarm limit property for an Alarm.
Ezerhan
(3,015 Views)
Ezerhan:
I think the function you're looking for is "Configure Alarming." You can find it on the functions palette in "DSC Module >> Engine Control >> Variables & I/O Servers."
Good luck! It sounds like you're picking it up pretty quickly.
Caleb Harris
National Instruments | http://www.ni.com/support
(2,998 Views)
