Application standalone with OPC server
Hello everyone!
I begin with question: Can I build an standalone application which includes OPC server?
I make an labview application which uses an OPC server and I want to build this application and then an installer for this. I want to use this standalone application on a PC who any Labview program are not installed. I try to use build this application but I think I missed something, because the application does not connect to OPC.
Thank you for your time and advices!
Marius B.
(3,274 Views)
Hi Marius,
Here are some links that might help you use the OPC server with an executable:
https://forums.ni.com/t5/Example-Code/Dynamic-OPC-Server-Discovery-and-Connection-Reference-Example/...
Here is another discussion post about a similar issue:
https://forums.ni.com/t5/LabVIEW/How-do-I-deploy-an-OPC-server-on-a-Run-Time-system/td-p/1119860
Paolo F.
(3,221 Views)
Have you got a deployment license?
Have a read of this: How is OPC Servers licensed?
CLA
(3,211 Views)
