myRIO I2C IP problem
Hey guys,
I am using myRIO and the following IP to be able to read from two different slaves:
NI 5644R LabVIEW FPGA Inter-Integrated Circuit Example https://decibel.ni.com/content/docs/DOC-26410
Here an example of its documentation for using the master.vi:
Now I have 2 questions:
1, As the myrio doesn't have the DIO-Config: "output enable done" can I use "set output enable" and set it to false?
2, I dont understand, how to use this VI and communicate with multiple slaves. The documentation says it is possible but not how to do it.
"The 10-bit addressing I2C standard adds an additional byte to the I2C transaction allowing a wider array of slave devices to be accessed." I am not sure what this means, maybe someone can help me.
Kind regards
Slev1n
(3,885 Views)
Hi
Have you already found a solution?
Kind regards,
Alex
(3,759 Views)
Hey,
I found some driver from plf consulting (ni.decibel). After some minor changes it works for me 🙂
(3,739 Views)
