Application subvi works fine in LV but not in exe
I have an application where I call a "display results" vi that resides inside of a T/F case structure. In the development environment it works fine but in the exe it doesn't work. The front panel appears but it doesn' really "run". I've checked my properties, paths, etc. I'm clueless. Thanks in advance.
PaulG.
Retired
(3,129 Views)
Accepted by topic author PaulG.
Check the error wire that enters the VI which pops up. Classic problem to have an error condition in a exe caused by some other build/path related issue.
Br,
/Roger
Edit: Crappy wording
(3,125 Views)
We are probably going to need to see some code
(3,110 Views)
Don't you worry. It's the error wire. Smiley Tongue
Br,
/Roger
(3,103 Views)
Exactly. Error message pointed right to it. What's strange is that it works in the development system. It should not have for the same reason.
PaulG.
Retired
(3,102 Views)
The application builder is a life-form of its own.
Full of mysterios little quirks and lots of deciet and trickery are needed to outmanuver it.
It's zen-like in its slowness but still ready to bite any second you look away taking another sip of coffe.
Smiley LOL
Br,
/Roger
(3,099 Views)
