Convert labview 5.1.1 llb to 2010
I would like to use the attached LLB with labview 2010 but i can't, because it was done with labview 5.1.1
(3,390 Views)
Post it in Version Conversion Board
(3,389 Views)
You can save the old code in LabVIEW 6 or 8.1. After that you must mass compile the old code. The output file is now compatible with LabVIEW 2010.
You can use this KB as a reference:
http://zone.ni.com/reference/en-XX/help/371361G-01/lvupgrade/upgrading_from_previous_version/
Miguel Fonseca
Applications Engineer
 http://www.ni.com/support
(3,366 Views)
I need the attached vi which is 5. version to be converted to over lv 9 or over version
could someone help me??
(2,845 Views)
Read the thread completely you have the way to do it.
(2,839 Views)
