Application working on Laptop with Labview Installed but not on other computers with no labvoew
i have wriiten a program to data acquire using usb 6221.
I have built application and it runs and works on my laptop where labview is installed. When I put it on to another computer with no labview, it does not work. The application will load and run but the data acquisiton does not work.
I am using labview 7.1 on my laptop.
I have th elatest DAQmx drivers etc on the computer I want to run the applciation on.
Has anyone elese seen this problem and now hopw to fix?
Message 1 of 9
(4,142 Views)
hi,
The application has to be built with LabVIEW Runtime Engine included.
Simply go to Installer Settings tab, checks the Create installer check-box, click on Advanced... button, include the RTE etc., and build it.
The built installer will install both the application program and the RTE on the deployment machine.
Hope above is correct and useful to you 😉
Ian F
Since LabVIEW 5.1... 7.1.1... 2009, 2010, 2014
依恩与LabVIEW
LVVILIB.blogspot.com
Message 2 of 9
(4,139 Views)
i had already included that in the installer, but still no joy
Message 3 of 9
(4,123 Views)
What DAQmx version are you using?
Do check the NI-DAQ & LabVIEW Version Compatibility (for Windows)
Take note that version higher that 8.9 will not support LV7.1
Message Edited by ian fung on 04-15-2010 05:45 PM
Ian F
依恩与LabVIEW
Message 4 of 9
(4,120 Views)
In my point of view it's not compatibility issue as the application is running on laptop with LabVIEW 7.1 .. It is certainly the issue of DAQ driver installation on target computer.. Please include the proper DAQ driver in your exe or installer package.. I can't see any other problem in application deployment .. just check the proper driver and runtime engine..
Message 5 of 9
(4,086 Views)
Did your installer include DAQmx Runtime?  Does your application use channels and tasks that were defined in MAX?  If so you will need to export those settings to the target pc.
Message 6 of 9
(4,068 Views)
Agree with Wayne. That might be one of the possible reasons.
Ian F
依恩与LabVIEW
Message 7 of 9
(4,043 Views)
 That's where the source of suspicious came from... though maybe I am wrong 😉
Ian F
依恩与LabVIEW
Message 8 of 9
(4,042 Views)
Second that. It should be the DAQ-mx driver and runtime is not installed somewhere. Last time i also do have similar problem but it due to different version of device drivers used between my host computer and dispatch computer.
If no labview runtime, it will prompt and say runtime ..... not found. If device driver is installed wrongly or partially, the application will still run but behave in a weird way.
Message 9 of 9
(4,024 Views)
