Aquisition donne
Hello everyone...
I am newbie in labview ...
I ' uses Adlink DAQ-2214 for a voltage aquisition of 2 channel (ch0 and ch1).
ch0 on the signal for speed and the Ch1 signed for vibration
I want to know if we could read the variation  frequency of a signal on the CH0 '' the voltage is -10V to 10V '
thank you
Message 1 of 8
(4,428 Views)
Accepted by santatra2
Hi santatra,
sure you can. As long as Shannon-Nyquist criteria is met you can determine any frequency in your signal…
Message 2 of 8
(4,393 Views)
Thank you for your response...
I use Labview 2015 with Win XP
I communicate you will seal my LBB
I 'already have both value (rotational speed and vibration) that I want displayed on an XY graph but I' just gets a point that wanders in the graph.
how to have a graph deroulant based on both value
NB : the vibration Y axes and the rotation axes X
thank you very much
Message 3 of 8
(4,340 Views)
Hi santrata,
A graph just displays the data you provide it - it doesn't has it's own internal data buffer…
You need to collect the data in a buffer (aka "array")!
As I cannot open your LV2015 VI right now that's all I can say.
Why did you save it within a LLB? That doesn't make sense for a single VI…
Message 4 of 8
(4,329 Views)
Thank you for your  reply
I tried to put the values in a table,
the problem it's that vibration is types "Dynamic", while rotation types "precisions dual 64-bit" and I can not put all in array.
may be that there are "vi" in labview who do directly?
thank you
Message 5 of 8
(4,316 Views)
Hi santrata,
you can always convert DDT data to more useful datatypes - you will find functions to do so in the ExpressVI functions palette!
Message 6 of 8
(4,311 Views)
Message 7 of 8
(4,309 Views)
Hi santatra,
what a "nice" image! (sarcasm!)
Notes:
- You could clean up your VI to have straight wires (atleast)!
- Attaching a real VI (or a snippet) would allow us to check the parameters of your ExpressVIs…
- Whats the point in converting a DDT wire to a 2D array to convert that back to DDT?
Message 8 of 8
(4,280 Views)
