09-12-2014 09:05 AM - edited 09-12-2014 09:05 AM
I would like to create a program which simulate the signal given by the contraction of a cardiac chamber. It should be periodic with a settable frequency and amplitude. I've been using an event structure with a timeout interval equal to the time interval of the signal and a "simulate arbitrary signal" block. The problem arises when I plot the signal because the graph shows all the waveforms side by side instead of been not zero only after the set time interval. You can find attached an example of the signal I would like to get and the one I get and the labview VI.
I hope that my question is clear, thanks in advance for the help.
Federico
Solved! Go to Solution.
09-12-2014 09:07 AM
09-12-2014 11:14 AM - edited 09-12-2014 11:18 AM
Ok, but how can I set the duration of the flat line in real time?
09-12-2014 11:41 AM - edited 09-12-2014 11:42 AM
So you want something like this?
09-12-2014 03:04 PM
Thanks for the quick help.
Federico
