Arduino ADXL325 through COM port
So I have created something like this on the picture. Unfortunately, it does not read any values. Also, such an error shows up. I will try to simplify the code, print only numbers and then read it in LabView I suppose.
Message 11 of 16
(1,019 Views)
I said those need to be %.3f.  I did not suggest %f.
Put an indicator on your raw string.  That way we know if anything is coming through.
Message 12 of 16
(1,011 Views)
I put %f.3 there but took a screenshot without it, my mistake.
So, after adding this "raw data" indicator, angle_xz worked, but angle_yz did not 😐
Message 13 of 16
(990 Views)
Accepted by topic author michcie
%f or %.3f should work.  It is concerning to me that you are only showing "84" for angle_xz.  It should be showing "84.026".  Are you in a part of the world that uses a comma as the decimal separator?  If so, your format string should be "%.;angle_xz=%fdgangle_yz=%fdg".  The "%.;" at the beginning forces the use of a period as the decimal separator.
Message 14 of 16
(978 Views)
Yes, you are right and it worked 🙂
Message 15 of 16
(970 Views)
It looks like yz worked as well.  It just happened to be 0!
Message 16 of 16
(965 Views)
