Arduino Error 5005
In my PC running Windows 8 professional,I can only find "Communications Port(com3)"  in devices manager after I installed the Arduino Uno driver.  I fixed the 5002 error by changing com3's default setting of baut rate  to 115200.
Message 11 of 16
(2,859 Views)
I have done the same thing with may Arduino UNO. But i didn't work.
I placed a stop button with while loop. I stop the programm with the button and it is working.
Message 12 of 16
(2,760 Views)
This thread is no longer active, as the last post's date was November of 2012. I suggest creating a new thread, outlining the error you're getting, steps to reproduce, hardware/software you have installed, and all troubleshooting steps you've taken so far. Our community will be better able to assist you with a complete description of your error.
Nathan Murphy
C Series I/O Product Manager
Message 13 of 16
(2,746 Views)
Hi, everyone!
I have the error 5005, I already tried everything that I had found, included these tips. The problem is that althoug I set the VISA resource, LabVIEW does not found any port, I mean, the control appear empty and, even I have tried to set manually the COM number, LabVIEW not recognize it. I have VISA installed properly, I have the drivers in order and, I have not any idea about why the ports are not recognized.
In advance thank you for your support.
Best regards!
Message 14 of 16
(2,705 Views)
Hey;
I have problem same as Crystal71 what he wrote.
Any suggestion for these problem.
Thanks.
Message 15 of 16
(2,576 Views)
This thread is no longer active, as the last post's date was in 2013.Please create a new thread, outline the error you're getting, steps to reproduce, hardware/software you have installed, and all troubleshooting steps you've taken so far. Our community will be better able to assist you with a complete description of your error. Thanks for choosing NI, and have a great day!
Best Regards,
Roel F.
Message 16 of 16
(2,545 Views)
