Arduino Linx Labview Use Analog Input as Digital Output
Hi I using Arduino as a DAQ of Labview.
Im using Arduino LINX Module.
My problem is i need to use the Analog input as Digital Output in my Arduino Mega 2560 board.
In Arduino IDE i can do this by calling the analog pin A0 as pin 54.
Here in LINX i got error when i use the pin 54 it says:
The specified Digital Output channel (54) is not available on the Arduino Mega 2560. The following channels are available: [0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53].
(1,041 Views)
Hi popul,
Here in LINX i got error when i use the pin 54 it says: …
Then you should use the ArduinoIDE with all its options to program your Arduino!
LINX isn't made the provide the most flexibility, but to provide a fixed set of supported functions.
When you want to go beyond that fixed set you need to use something different than LINX…
(898 Views)
You can still use an Arduino as a DAQ in LabVIEW, but you'll have to write the functions yourself and transmit them via serial. I'd recommend using JSON to format the values going between the two systems.
(882 Views)
