Arduino analog input
Accepted by Hatemaboud
@Hatemaboud wrote:
ok so now when I upload the LIFA_Base I get an error message says (( this chip is not supported))
LIFA has long since been deprecated and replaced by LINX
Here's a tutorial to get you going. Getting Started with LINX
In this tutorial we'll install LINX, setup a new LINX device and run our first example
=== Engineer Ambiguously ===
Message 11 of 15
(2,122 Views)
LINX can be quite a bit easier to use than LIFA ^
(You are currently using LIFA)
Studying for CLA.
LabVIEW, inherit from social media habits!
Message 12 of 15
(2,118 Views)
Thank you so much, now it Works.
but still have a small question; it takes few seconds to start reding the signal from the potentiometer at the begining then when it starts reading it continues well, is that normal or there is something wrong!?
Regards
Hatem
Message 13 of 15
(2,104 Views)
Thank you so much, now it Works, but still have a small question; it takes few seconds to start reding the signal from the potentiometer at the begining then when it starts reading it continues well, is that normal or there is something wrong!?
Regards
Hatem
Message 14 of 15
(2,102 Views)
It is normal that the setup of communication can take some time.
Message 15 of 15
(2,090 Views)
