Are there any Octal to ASCII string converter?
Hi guys, one question. Are there any Octal to ASCII converter available in labview?
Message 1 of 14
(9,797 Views)
There is a Number to Octal String in the String -> Number/String Conversion palette.
Otherwise, use Format into String with %o format.
Paolo
Message 2 of 14
(9,789 Views)
The one you saying right now is any number or string convert to octal, somewhat like this.Capture.PNG
But i need now is to convert Octal to ASCII. It's different.
Message 3 of 14
(9,784 Views)
How about changing the format string from your %02x to %03o? That is exactly what pincpanter was saying. If that is not what you want to do, show us some code of what you want to achieve, rather than what you do not want.
Rolf Kalbermatter  My Blog
Message 4 of 14
(9,774 Views)
So the question is: what's Octal? There is no such thing at low level. For me, octal is only a specific visual representation of integers or "bitstream" data.
Paolo
Message 5 of 14
(9,764 Views)
This is what i want.
It's easy to convert ASCII to any base, just play with the format string, but if want to convert back, it takes some understanding.
I'm still new to labview btw
Message 6 of 14
(9,745 Views)
Just do what pincpanter and rolfk say and replace the FF / hex functions you have with the ones rolf showed you. It's a direct swap!
CLD; LabVIEW since 8.0, Currently have LabVIEW 2015 SP1, 2018SP1 & 2020 installed
Message 7 of 14
(9,742 Views)
So what's wrong with the inverse functions from my post? The Octal String to Number function is right besides the Hexadecimal you show in your example.
Also note that part of the confusion is likely in your use of what represents the ASCII side. Many people consider the ASCII part the human readable text side, while the hex/octal/decimal number side is the machine representation.
Message 8 of 14
(9,731 Views)
Accepted by oliver1023
So you have an input ASCII string containing (3-digit?) numbers in octal format and need to scan it to U8 values.
The code is much the same you posted for hexadecimal format, but using Octal String to Number instead of Hex String to Number. Probably extracting 3 characters at a time.
You may also use Scan from String with %3o format, see just as an example this code:
Paolo
Message 9 of 14
(9,726 Views)
I'm just asking are there any code for this....
Message 10 of 14
(9,698 Views)
