Arrange the peak magnitude values of multiple strain gages according to their locations.
Greetings Vgrchada.
In order to resample unevenly space data, try the Resample (constant to variable).vi or the example in this forum I found.
Yes, the result of the integration will be a single point. You have to select subsets of the resampled array and for each single point (which represents the integration of the subset) assign an X position in another array. (For example, if you select a subset of points 0 to 9 of the resampled signal, assign an X position of 10; then select a subset of points 10 to 19 and assign an X position of 20; and so on) Then, build an XY graph so that the result of each individual integration operation is plotted at the proper X position. Finally plot that waveform in the same XY graph. The result is basically what you want.
Have a nice day.
Luis J.
Message 31 of 31
(380 Views)
