Array Element feeding?
Hi guys
How do I get the element of array and use it to feed my device to that value.
e.g I feed the value 0 to my device then 1..... until I finish feeding 19.
(3,573 Views)
  • Put the feeding operation inside the FOR loop. No array needed.
  • If you already have the array, autoindex over the array with another FOR loop containing the feeding operation (whatever that is). 🙂
(3,567 Views)
... or if you only want a single value - Index Array.
/Y
Qestit Systems
Certified-LabVIEW-Developer
(3,543 Views)
