Remove dark portion from Image
I have just started working with NI VISION. I have attached one image with this post.
Can some one tell me how I can remove dark part in image? I read about histogram, which gives total number of pixels at each grayscale level.
But I don't know how I can use this information to improve image quality or in my case how I can use it to equalize the pixel values encircled with rest of the image.
I hope I have explained my problem properly.
Gaurav k
CLD Certified !!!!!
Do not forget to Mark solution and to give Kudo if problem is solved.
(4,251 Views)
What kind of camera do you have? FireWire, GigE, CameraLink?
If it's a CameraLink one, you could take a look at the example VI : C:\Program Files\National Instruments\LabVIEW 2010\examples\IMAQ\IMAQ Color.llb\Color Processing.vi
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
Antoine Chalons
(4,237 Views)
I have USB camera of Imaging source
Gaurav k
CLD Certified !!!!!
(4,213 Views)
Accepted by topic author Gak
I found the solution of the problem. I used "Pixel Manipulation".
If anyone has any better ideas then please share.
Gaurav k
CLD Certified !!!!!
(4,191 Views)
Probably not a "better" idea, but mybe a source of idea, here's an example to manipulate color planes of an RGB image. It's very basic, it lets you amplify of reduce a color plane by multiplying it by a number between 0 and 2.
LV2010.
Epictetus
Antoine Chalons
(4,182 Views)
Thanks I will try this.
Gaurav k
CLD Certified !!!!!
(4,171 Views)
