Array Interpolation
hello,everyone!I had asked a similar question in here http://forums.ni.com/t5/LabVIEW/Array-Interpolation/m-p/2819440#M825228,But now I want to know how this interpolation:In a [1] to insert a value, in a [3] to insert three values, in a [5] to insert five values , so that in turn the cycle continues until it reaches 100,I do not know how to do , hoping to get help, thank you!
Message 1 of 12
(4,987 Views)
Just to make things clear, what you are asking has nothing to do with "interpolation" unless the element that you insert contain a proportionally interpolated value based on the neighbors.
You need to be much more clear in the problem description. what does "in a [1]" or "in a [3]", etc mean? Please show us a small sample array and tell us how it should look like after the various operations.
Message 2 of 12
(4,942 Views)
First of all thank you for your reply!I want to achieve is such as the following:left-----right!360软件小助手截图20140427103924.png
Message 3 of 12
(4,932 Views)
Well, this seems to be another homework.
What have you tried so far and where did you encounter problems?
Message 4 of 12
(4,913 Views)
sorry!I made a mistake,The following picture shows the relationship is in need of conversion;
I refer  to the VI You gave me before;I started the next test , but that the number of intervals of each insert is a fixed value,The number of insert values can not reach a situation of increasing,And I looked over all the array vi,Does not seem to help,please give me some Proposal,thank you!Conversion relationship needs
Message 5 of 12
(4,904 Views)
Again: What have you tried and where did you encounter difficulties. Show us some thought process and solution attempts and we will guide you in the right direction. This is a help forum, not a homework service.
Message 6 of 12
(4,898 Views)
Hi dfaweew,
it seems you need to do this:
- in the 1st iteration you take one element and append one zero.
- in the 2nd iteration you take the next two elements and append two zeros…
- in the 3rd iteration you take the next three elements and append three zeros…
Did you get the scheme?
As Christian said: start to code , attach your VI and tell us, where you run into problems with it!
Message 7 of 12
(4,889 Views)
hello!
I 've used this vi to achieve functional ,As shown in FIG.but now i need to do this:
- in the 1st iteration you take four element and append four zero.
- in the 2nd iteration you take the next eight elements and append eight zeros…
- in the 3rd iteration you take the next sixteen elements and appendsixteen zeros….....Cycle....like show at Figure 3
I tried to achieve this by the way  in Figure 2.
But think of the shift register can not seem to realize the functions I want to achieve;and I also want to use Decimate 1D Array Function and Interleave 1D Arrays Function to achieve ,But still can not seem to find it;I now have no way;Please give me some valuable suggestions or tell me how to do,Best regards,
FIG 2fig 2fig 3
Message 8 of 12
(4,814 Views)
You should be ashamed to post code pictures with hidden an right-to-left wires. Next time attach the VI instead. You are also doing this way too complicated. Try to do it with a single loop and 25% of the current code. For the second problem, you can use the same counter but scale the value with powers of two.
Message 9 of 12
(4,806 Views)
Thank you for your reply!you say do it with a single loop and 25% of the current code. can you Change my vi or attach your vi!It sounds easier said than done,Best regards,
Message 10 of 12
(4,775 Views)
