problem with ni vision assistant
Hi all,
I am beginner in LabVIEW. I started using NI Vision Assistant 2012. As a newcomer to this forum, I have following doubts regarding my example for project
1) How to read images (20 or more) from a folder, sequentially.. & process them using Vision Assistant.
2) Is it possible to make the above process to be done automatically (I mean, continuous selection of image & processing them)
3) Display those processed images.
I am using .jpg format files. I am not familier with using Loops while processing images.
i have attached my VI
Thank you for your time.... 🙂
(2,792 Views)
Please go through the LabVIEW basic trainings and get familiar with the LabVIEW environment (You may find in this post ) .
You can find some examples in LabVIEW example finder under Vision. For simple image reading and processing am sure you have some examples there.
(2,775 Views)
