Array Refnum Number of Rows size of data array
I have read
array size from refnum - NI Community
the Problem is 17 Years old and i hoped the Number of Rows/ Number of Columns Property would have fixed that but is seems these propertys only give the frontend displayed size and not the actuall data size back.
is there a better way to get the size of an array by refnum then flatten its value and reading the first bytes?
(3,255 Views)
If the refnum is strictly typed, the Value property will do what you want. If the refnum is a generic array, Value will return an array of Variant that you will need to convert to the actual value, element by element.
Paolo
(3,251 Views)
its generic and i only know it  has 1 Dimension and it is of some generic cluster with controles in it : /
(3,216 Views)
Accepted by PaulPascher
(3,203 Views)
@PaulPascher wrote:
... i hoped the Number of Rows/ Number of Columns Property would have fixed that but is seems these propertys only give the frontend displayed size and not the actuall data size back.
That's the purpose of these properties, so there is nothing to "fix". The array size is not a property, but part of the data and you already got good suggestions.
(Can you explain why you think you need all that? Maybe there is a fundamentally better way to do whatever you are trying to do.)
(3,185 Views)
You'd think the Get Array Information from the Variant pallette would answer this, but alas.
Qestit Systems
Certified-LabVIEW-Developer
(3,134 Views)
