Array and Number problem
I've run into a problem while writing a particular sub.vi whose purpose is to, depending on a specified range, spit out a bunch of different test parameters.
The issue, as shown in the attachments, has to do with the fact that for the majority of the ranges, it spits out an array of frequencies to test.  However, there are a few ranges that only require 1 test frequency, and I cannot make an array that is only 1 entry.
This .vi acts as a sub.vi in a larger program, and I really need them to all go to the same indicator (the "Frequencies" array).
(2,763 Views)
Accepted by LarsUlrich
In the broken wire insert a Build Array.  It will create an array with only one element.
The output indicator requires an array.  The number of elements in the array can be zero, 1, ... ~2^32.
Lynn
(2,755 Views)
