Array constants grayed out upon opening, even when set to default
Hello LabVIEW community,
I have a circuit set up with (8) TMP36 temperature sensors connected to an NI 6002. Before the VI runs, I want the user to enter in ambient temperature values as constants within a control array. I also have constants elsewhere in the VI for calibration and offsets. My problem is that four of the eight array constants are "grayed out" when I reopen the VI. I have tried right clicking on the value and selecting Data Operations > Make Current Values Default and Reinitialize to Default Values. The VI will not collect data for the four values that are grey upon opening unless I double click them and renter the values every time.
Any help would be extremely appreciated!
Thank you,
Anne
(3,418 Views)
Accepted by anneb312
Those arrays are grayed out because they are empty.
When you right-click on an array element and set it's default value, you're setting the default only for the element, not for the array.
To set the default for the array, right-click on part of the array that's not an element (such as the index).
(3,393 Views)
Hi Paul,
That worked, thank you very much!
(3,357 Views)
