Array creation and usage - part 2
Now I have an array. Is there a way pull out a single element modify it and replace it? Multiple elements?
thanks
Message 1 of 16
(6,023 Views)
Message 2 of 16
(6,019 Views)
http://www.google.com/search?&q=arrays+in+labview
Andrey.
Message 3 of 16
(6,013 Views)
Thanks but Replace Array Subset does not like having the output tied back to the input array.
Message 4 of 16
(6,010 Views)
Accepted by topic author jvh75021
Hi jvh75021:
Now that you have an array, you can perform several operations on it:
1.- You can pull out a single element by using Index Array.
2.- After you pulled out the element, you can modify it without problems.
3.- You can replace it using Replay Array Subset.
If you want to pull out contiguos elements in an array, you can use Array Subset.
If the elements are not contiguos, you can use Index Array in a loop.
You can find all the Array functions in the Functions Pallete>Programming>Array.
Luis Guizar
Message 5 of 16
(6,009 Views)
And you can't. If the source array is a control then you can write it back to itself using a local variable or a property node. If it's a wire (such as the output of a VI or a function, then you can't do that. You would need to create an indicator to see the new array.
Message 6 of 16
(6,004 Views)
Excellent. The first result,
http://cnx.org/content/m14768/latest/  ,
has some excellent videos.
Message 7 of 16
(6,003 Views)
Thanks, just wasn't looking for the right keywords. I was thinking read, write, etc.
Message 8 of 16
(5,999 Views)
Just for completeness don't forget about the example finder. If you type arrays on the index tab you will come up with examples such as 'Build Arrays.vi' and 'How to Replace Elements in an Array.vi' and so many more. Remember that context help and highlight execution mode will help greatly in understanding how these work.
Hope this helps.
Now Using LabVIEW 2019SP1 and TestStand 2019
Message 9 of 16
(5,977 Views)
I'm surprised nobody mentioned the In Place Element Structure yet...it lets you modify the array element without making any extra copies:
Message 10 of 16
(5,962 Views)
