Array last element display if scrollbar is on
is there a way to have an array of N elements with scrollbar but prevent the N+1 -th  element from showing?
This is what happens when you add a scrollbar:
2018-05-31 11_11_30-Test Selector.lvclass_Test Me.vi Front Panel on UniMove.lvproj_My Computer _.png
.. and this is what i would like: (ms paint work)
Thank you for any suggestions!
(3,404 Views)
You can "play" with external scrollbar.
(3,381 Views)
You're right, external scrollbar is an acceptable workaround, although a little bit awkward.
(3,375 Views)
The extra element is a feature, it allows users to 'grow' the array (add elements to it). Definitely not something you'd like to have as a programmer, but sadly there's no control over it... DIY is the only way out.
(3,372 Views)
