Calibrate DMM PXI-4065
i was looking for a way to calibrate my DMM, i find this doc www.ni.com/pdf/manuals/374460d.pdf they use Fluke 5700A, but i don't have it, can I calibrate my DMM using only LabView?
Thank you guys 🙂
(3,092 Views)
Accepted by topic author jazz94
No, programmatically it's impossible.
For thе calibration, you need an external device with an accuracy higher than yours.
Not necessarily a Fluke.
(3,086 Views)
Thank you for your reply, I was wondering if we could do a configuration in LabView just before my DMM takes a measure to calibrate it using the DMM functions (Calibration) ?
(3,066 Views)
As I understand, only 407x DMMs (and probably 408x) support the self calibration :
http://www.ni.com/white-paper/8321/en/#toc1
M-Junior
(3,043 Views)
