Array of cluster with string controll??
Hello again!
Now we have another type of problem. We have an array of clusters. The cluster is built by two controlers. One is a string and the other is a menu ring. How can we get a text in the strings that stays there even if one close the program. The text is supposed to be different. Example: B1, B2 and so on. then we want to be able to choos from a menu ring different options that are coupled with B1, B2 and so on. Best regards.
(2,783 Views)
Have you tried filling the array and then make those values the default ones?
To do that, right click on the control and choose "data operations" -- "make current value default".
Hope it helps,
Paulo
(2,775 Views)
Using "make current values default" will save a set of default values into all controls on the front panel. If you want the values to not just be default but be saved from run-to-run you need serialization of controls. When initializing controls (usually before the main user loop) you feed your controls data from a stored file and at the end of the program the settings are stored back (overwritten) to the same "preference" file. Reading and writing complex data forms might seem like it would be a pain to implement but Labview has a nice method for such data persistence. Use the Advanced>>Data Manipulation>>XML VI's. Flatten your control to XML using, you guest it, "Flatten to XML" then use write XML to file to save settings. Do the reverse to initialize controls by reading XML file and unflattening XML data. I have had nice results with these VIs in the past and although not the most compact data form (we are in the age of 100+GB hard drives so what's a few bytes between friends?) will give you well formatted data with almost no additional work. If you just want default data settings and not data persistence then ignore this message.
Paul
Paul Falkenstein
Coleman Technologies Inc.
CLA, CPI, AIA-Vision
Labview 4.0- 2013, RT, Vision, FPGA
(2,764 Views)
