Serial port reconfiguration
Serial port reconfiguration.
My goal is to send via serial communication interface one packet of bytes with a slow baud rate (150 baud) and after this, another packet is requested with another baud rate (9600 baud).
To do this I have used this tecnique:
- Open serial port with slow baud rate
- Send the first data characters
- Close serial port
- Reopen serial port with fast baud rate
- Send the seconds data characters
All seems to works fine, but my problem is in the long time required during baud reconfiguration.
I have noticed that function ‘CloseCom(comport)’ takes a long amount of time and this time is related with baud rate.
For example with baud rate of 150 baud the CloseCom() takes about 800msec to finish its task. With 300 baud this time becomes about 400msec.
Thanks very much for any help.
Flavio
(the environment is : CVI=7.0 OS=WIN-XP)
(3,183 Views)
Hi Flavio
From your description I think your problem relates to LabWindows/CVI rather than LabView.
Try posting your query on the LabWindows board instead.
Regards
Neil
(3,178 Views)
Thank you,
now I’ll try in the correct board.
(3,163 Views)
I'm not familiar with Labwindows/CVI, but in Labview there is no need to close the serial port to change speeds. I have a program that does this with no problems.
(3,155 Views)
