Array of the push button
I am using array of push button. I want to know which number of button has been pushed. I want to know button position. For that, Accoding to my knowledge It can be get it from Arraz indexing method. However I can not get it. Could any one has some idea.
My major goal is to get the button number which is pressed or unpressed.
(1,649 Views)
Accepted by topic author Rshah31
Qestit Systems
Certified-LabVIEW-Developer
(1,633 Views)
@Yamaeda wrote:
Personally, I prefer "not equal" where that diagram constant must be a TRUE, of course.
Also, of you want to know the new value, use the blue value to index into the newval array.
(1,591 Views)
Thank you @Yamaeda  and
your solution works!
have a short question on that,
If button 1 is pressed = True, I want some mgs "Button is pressed "
and if button 1 is unpressed = False, I want some mgs "Button is unpressed "
Even if Any button is already pressed, let's say button 2 is already pressed, it does not affect the other buttons' value
In this senario. I would prefer to use CASE structure "True" and "False". But I could not understand which value do i need to attched with Case structure.
Please give me your guidance or any other idea.
(1,538 Views)
Hi Rsash,
Use the "new value of changed boolean" as shown by Altenbach.
Do you understand his example code?
(1,531 Views)
Hi GerdW,
Before, I understood it incorrectly, but now I am clear.
Thank you for giving me the right direction.
Thank you to all who are involved in the conversion!
BR.
(1,516 Views)
