Array problem
Small question about arrays:
See attatched problem.vi. How can I add the values to the array, not only change the value at index 0 each time I press the button.
Message 1 of 8
(3,765 Views)
Plz attach in LabVIEW 7.1 version or paste a pic of block diagram
regards
Dev
Message 2 of 8
(3,758 Views)
I have only Lv 7.1 version, can you resend that code plz?
Message 3 of 8
(3,757 Views)
Sorry, my LV8 is not installed by now....
To attach one value at index 0 you can use the build array function. Top input is your new value, second your array.
BUT try to avoid the build array function if you don't do once in a while since it will allocate new memory and costs system performance on big arrays.
Greetings from Germany
Henrik
LV since v3.1
Message 4 of 8
(3,757 Views)
Here is 7.1. Sorry about that 😉
Message 5 of 8
(3,756 Views)
Hi Christian,
here u are!
In the attached VI, just see how i am insertig new elements into an array
Use either Build array or insert into array
Use build arrays for large arrays with care,  as it will load ur memory
Regards
Dev
Message Edited by devchander on 12-16-2005 03:24 AM
Message Edited by devchander on 12-16-2005 03:27 AM
Message 6 of 8
(3,751 Views)
here you go
Henrik
LV since v3.1
Message 7 of 8
(3,746 Views)
Thanx. That was quick Smiley Happy
Message 8 of 8
(3,737 Views)
