How to avoid Plots decrease file writing speed ?
My application has a plot of 7 charts and data logger. However, this plotting is decreasing the writing file speed. I tried to use paralell loops with queues, (ploting in a different loop in different threads) but it's still decreasing speed. When the program disables the plots, the speed increases drastically.
Any clues ?
RKO
(3,715 Views)
How big are your history buffers?
(3,706 Views)
I'm not using history buffers. The application acquires data, processes the data and saves one sample at a time ploting in the chart. I tested implementing a buffer to write the buffers, but I still get the delays on the file writing. The data is lost at every 20ms. If there is no plot of data, the file writing is ok.  There are 7 chart plots. Decreasing to 4 plots, the loose of data drops to 10ms.
The points when ploted off-line (reading the file) are like this
......... - 10ms of "silence" - .............. - 10ms of "silence" - ...............
The dots represents data points, and "silence" means loose of data.
In this aplication, I cannot rely on the Sample rate of the board, because of the processing, so I implemented a timebase counter (based on the internal "tickcount" function of LAbVIEW).
ricardo
RKO
(3,690 Views)
All charts have built-in history buffers. You can configure them by right-clicking on the chart. 😉
It is hard to tell what the problem is without seeing the code, there could be many different issues. How many parallel loops do you have? Does each loop have a small wait statement?
You can also save some processing by turning off autoscaling, etc. Are the charts just lines or more fancy with dots, etc.? Also make sure they are not set to "synchronous display".
Could you attach your code?
(3,675 Views)
You were right ! I turned off the autoscale and it's good now. But I spent good hours with this and some headaches.
RKO
(3,656 Views)
Someone might correct me if I'm wrong:
As you wrote, you try to put the display and the save routines in different threats and pass the data with queues. However if both routines have indicators/Controls showing on the/(a) frontpanel they will both run in the same UI-threat.
Again, it's hard to tell without code.
Greetings from Germany
Henrik
LV since v3.1
(3,649 Views)
next thing: do you use (double) buffered aquisition?  Sounds like a point by point reading. Hello CodeSmiley Wink
If your apisition fails by enabling the autoscale, it might also fail if there are other system tasks (moving windows with mouse)
Henrik
LV since v3.1
(3,646 Views)
